will a 700r4 fit any v6 or v8?
Old Jul 23, 2008 | 11:40 AM
cheschire21's Avatar
Car: 88 camaro convert
hey all
i bought a 88 convertible that had the original 305 pulled and had a 350 put in. my trans slips between 1st & 2nd gear. a friend told me i can have his 700r4 that worked and has been sitting for quite a while. this was pulled out of a v6 he thinks. my biggest problem is that i don't know if they swapped my original tranny with the motor or they left it.
will a 700r4 fit in any camaro?
any feed back would greatly be appreciated!!
Old Jul 23, 2008 | 11:57 AM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Re: will a 700r4 fit any v6 or v8?
V6 tranny will not mate to a V8
Old Jul 23, 2008 | 11:58 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Only a V8 700R4 will fit a V8 engine.
Old Jul 23, 2008 | 12:23 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
I'm sure an adapter plate can be implemented if it really is from a V6, but the question here is though, why would you even want to. If your looking for a cheap, but strong tranny to replace the current one, I'd recommend a Turbo-350. If you insist on having overdrive though, go with your buddies for the time being, but don't expect it to last too long though. Not sure about the differences in spline count but I'm pretty sure they're different, so you'll want to look into that as well....
camaro11j
Sep 19, 2018 08:49 AM
C409
Sep 1, 2015 03:42 PM
someone972
Aug 30, 2015 12:52 AM
355tpipickup
Alternative Port EFI Intakes
Aug 26, 2015 04:08 PM
TreDeClaw
Aug 14, 2015 06:58 PM
