89 Camaro gears
Old Oct 15, 2000 | 10:35 PM
NRAGE's Avatar
89 Camaro gears
I have a 89 Camaro RS that came stock with a 305tbi and a 700r4 tranny. I have heard that in 89 they put 373 gears in the rear end. I am in the middle of a 355 swap and now is a good time to put in replacement gears if they are not 373.... Does anyone know? Also I have read in certain tech articles that the 89 rearend was the best 3rd gen rear, anyone else know anything about that?
Old Oct 15, 2000 | 10:45 PM
cobrakiller1989's Avatar
I know an 89 RS has a 2.73 open rear, I just put 3.73's with auburn limited slip in mine and there is a huge difference. The 355 helped also, I cant wait to go to TPI.
Old Oct 15, 2000 | 11:14 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
89 RS is an LO3. It's rated at 170HP @4400 255 torque @2400
1989 third gen with 305 and 700R4 tranny came with 2.73 gears only. No other options were available for that combination.
1989 was the first year of the larger rear disk brakes and the last year of the 26 spline axles. In 1990 they went to the larger 28 spline axles.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
LS6 Big Block buildup now in progress
Best results before the engine blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
Old Oct 15, 2000 | 11:51 PM
NRAGE's Avatar
Thanks for clearing that up. Now, on to jegs for the 373 gear setup. I just hope the stock TBI doesn't starve my 355 to death!!!
Old Oct 15, 2000 | 11:56 PM
NRAGE's Avatar
What is the difference between the 2 carrier #'s. I started looking and noticed 2 different ratio carriers, 3.08 and 3.23. How do I tell what I have?
Old Oct 16, 2000 | 01:11 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
No 89 car came with 3.73's from the factory. 2-series means your gears are 3.08 and lower. For our cars thats 2.73 and 3.08 are 2-series carriers. 3-series is 3.23, 3.42, 3.73.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
jklein337
Sep 19, 2018 06:23 PM
hectre13
Aug 26, 2015 08:17 AM
InfinityShade
Aug 22, 2015 08:00 PM
mizz0313
Aug 12, 2015 06:45 AM
