T-5 install problem...need help
Old Jul 24, 2008 | 07:40 PM
jakesTA87's Avatar
Car: 87 Trans Am
Engine: 350(5.7L)
Transmission: WC T5
Axle/Gears: Junk 2.73s
Im in the middle of a t-5 swap and i ran into my first problem. when i go to install the tranny, i cannot get it to slide all the way into place. it stops about a half inch from bell housing. i used an alignment tool with a dab of paint on the end of it and it goes all the way back to the crank. is it possible that the fingers(not sure what to call them) on the pressure plate are holding it back. let me know what you guys think.
Old Jul 24, 2008 | 07:46 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Re: T-5 install problem...need help
Try to install the slave and push the clutch in a bit, should slide in after that.
Old Jul 25, 2008 | 07:56 PM
jakesTA87's Avatar
Car: 87 Trans Am
Engine: 350(5.7L)
Transmission: WC T5
ok the tranny, drive shaft, torque arm, and cross member are installed...now i have to get the pedals and master cylinder mounted...can anyone tell me where the 2 braces go...i took a pic of them installed in the other car but managed to lose it and i cant remember how they go...any help is greatly appreciated...
Old Jul 26, 2008 | 07:47 AM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
the two pedal braces go on the studs that come through the firewall holding the master cylinder in place.
Old Jul 26, 2008 | 01:37 PM
jakesTA87's Avatar
Car: 87 Trans Am
Engine: 350(5.7L)
Transmission: WC T5
OK does anyone have a trick for getting the F****** pedals in without cussing and fighting...im about to say f*** it
Old Jul 26, 2008 | 01:58 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
after i unbolted the pedels and brake master cyl arm iirc it was very easy to install the new pedels. mine only took like 5 mins or so
Old Jul 27, 2008 | 09:16 PM
jakesTA87's Avatar
Car: 87 Trans Am
Engine: 350(5.7L)
Transmission: WC T5
Well it works.
I got almost all of the swap done. I took it out yesterday and today and drove it around and other than the sh***y 2:73s in the rear, it works great. Now i just need to find a connector for the back up lights and put the console back together. Well worth all the headaches
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
midge54
Sep 2, 2015 06:27 PM
Cacike
Aug 27, 2015 05:10 PM
