Ford 9 inch swap. Would everybody hate me if i did it?
Old Oct 17, 2000 | 02:51 PM
spitfire350's Avatar
What would be the pro's of a ford nine inch over a gm 12 bolt if any?
keep the stang's far behind u and the cops even farther
Old Oct 17, 2000 | 04:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
To answer your topic question, no.
As for 9 inch vs. 12-bolt, the Ford pieces are certainly more readily available. But, an arguement can be made for the 12-bolt being more efficient - i.e., less loss to the wheels (energy, not torque).
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 2.73 open. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Oct 17, 2000 | 06:01 PM
crazeinc's Avatar
the easy answer is hell no...a lot of people are using ford 9"'s in their thirdgens...
The 12 bolt, while nice is a bit harder to install in a thirdgen whereas companies already have bolt in 9" rearend's for thirdgen for about $2000...so it's you're call.
82 Z28
355 carb'd, Edelbrock Performer RPM package (minus heads), Hooker Super Comps, Mufflex 4" offroad y-pipe, 700r4 with B&M shiftkit, '85 IROC 10 bolt rear with Richmond 4.10's & Auburn posi unit, Lakewood 50/50 drag shocks. Shooting for 3000lbs w/ driver.
The car's website (New design in progress...very cool look)
(383/TH350 buildup this winter)
AIM: Unitedhope
ICQ: 77979548
Old Oct 17, 2000 | 08:19 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
With the 12 bolt you need to buy a 12 bolt housing that has a torque arm mount cast into it. Either that or you're going to use ladder bars or a 4-link. With a 9" you can find anyone that will fit and buy the bracket to use the torque arm.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
LS6 Big Block buildup now in progress
Best results before the engine blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
Old Oct 17, 2000 | 10:47 PM
at a motorsports place where i live they said they can put a new nine inch on and new torque arm, panhard rod and lower control arms for like 2300 is that fair or to expensive? thanx for the help
Old Oct 17, 2000 | 11:22 PM
812MANY's Avatar
That's a pretty good deal....
Old Oct 18, 2000 | 03:17 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
See my reply to this post. https://www.thirdgen.org/messageforu...ML/001955.html
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
$750 L98
Feb 1, 2025 02:25 PM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
86White_T/A305
Sep 21, 2015 05:28 PM
