82,83,84 4 speed muncie's
Old Oct 15, 2000 | 01:12 PM
chicksL69's Avatar
Hi, I have a question about the muncie 4 speeds that came in 82, 83, and 84 camaros. My question is how powerful are they, as far as holding up to high torque and HP. I know the borg warner 5 speeds sucked, that's why they only came with 305's and not 350's. I have an 84 camaro with a built up engine, and sometime down the line I'd like to put in a manual tranny. So how powerful are the muncie's? thank you
Old Oct 18, 2000 | 06:58 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Muncie transmissions were never used in 3rd gens. They were discontinued in about 74.
There were however a very few Warner T-10 4-speeds in 82s. The vast majority of 82s with manuals had Saginaw 4-speeds, which suck. Their strength is OK but it's a bit like driving a dump truck. The ratios are real wide, the shifter has real long throws, the synchros are small, just overall it's not a sports car sort of trans. 83 up got the T-5.
The T-10 is frequently mis-identifiead as a Muncie. It's an excellent transmission, when mated with 3.73 or 4.10 gears. I had a 79 Z28 350 for instance that came from the factory with a T-10 and 3.73s; I got the motor better than the factory's 165 HP, promptly blew up the 3.73s and put in a rear with 4.10s, and liked it. I had a 78 Z28 at the same time with a T350 and 3.73s. If you find a T-10 with the 3rd gen extension housing, it would be a great choice for a sort of retro approach or an all-out performance build with no consideration of gas mileage; it's probably worth alot of money even if you don't want to go that route. One of the things you would need for the swap is a shifter, and since there has never been a 3rd gen Muncie, there's also no such thing as a 3rd gen Muncie shifter from Hurst or anybody else. There is, or at least was, a Hurst shifter for the 82 T-10 combo, so maybe that could still be made to work.
Because of the rotated mounting of the trans, you have to use a 3rd gen trans of some kind, or be prepared to massively sodomize your car. If it's a race-only project then it's not a problem; but a non-3rd-gen manual trans is totally incompatible with the 3rd gen floor pan and interior.
Old Jan 28, 2012 | 07:30 AM
dansheldon's Avatar
Car: tube chassis 82 Z
Engine: 406
Transmission: Muncie
Axle/Gears: 4.10 9inch
Re: 82,83,84 4 speed muncie's
The 82 was not rotated.
$750 L98
Feb 1, 2025 02:25 PM
Elephantismo
Feb 13, 2019 12:51 AM
jrdturbo
Mar 31, 2016 02:58 PM
Giocio
Oct 1, 2015 12:20 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
