t5 trannys junk?
Old Oct 19, 2000 | 10:34 AM
ChinoMoreno's Avatar
t5 trannys junk?
Hey guys,
I have a t5 tranny in my 85 Iroc. The motor has been changed to a 350 from a mid-80's Vette. I have been told that the t-5 won't hold up to a semi-high performance 350. My 350 has a hotter cam, but is pretty much stock, although I am adding headers and a cat back system.
Also did Chevy make a beefier 5 speed manual than the Camaros t5?
Old Oct 19, 2000 | 02:57 PM
badbird88's Avatar
In 1988 GM started putting the World Class T5 tranny in the f-body cars that were stronger than your 85 T5. They are rated at 275 ft-lbs torque which just about any 350 will easily have. However, there are a lot of us who are running the T-5's behind modified 350's with no problems. The WC T5 was underated in my opinion. The problem you run into with them is continued abuse at a dragstrip b/c of the sticky track. Look at my sig, been running mine for over 4 years and lot's of dropping the clutch shifts from 1-2. I did rebuild my when I changed the motor.
1988 TA 300+hp 350 w/ TBI and Holley TB unit, Holley projection intake,
WC T-5, 3.42 gears w/ Auburn posi. MSD 6A, edelbrock TES headers, dynomax 3" cat and cat-back system, ACCEL coil, polyurethane bushings all around, aluminum driveshaft, Mr. Gasket open air cleaner.
1993 S-10 w/ 4.3L V6 TBI, slightly bigger cam, Mild polish job and 3 angle valve job on heads, Edlebrock TES headers, Dynomax cat back, MSD 6A, ADS chip
2000 Kawasaki KX 125
Old Oct 19, 2000 | 10:55 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I have been running my wc t-5 behind a moded 350 tpi and I have done every thing but, power shift with no clutch(I would not do that with a 4 cyl. either.)
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
bjpotter
Oct 4, 2015 07:48 PM
mfp189
Sep 27, 2015 09:25 AM
armybyrd
Sep 26, 2015 03:37 PM
