Loosing transmission fluid, can see it dripping!!
Old Oct 20, 2000 | 07:54 PM
Paul Holmes's Avatar
Where are all the possible locations on a 700r4 where fluid can leak. I'm gessing the pan, or the fittings where the tubes from the trans cooler and radiator go in. Where else might I check? Please help I lost a quart today driving around all day.
91RS-STROKER
Old Oct 20, 2000 | 08:43 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Check where the dipstick tube goes into the casing. There's a rubber cylinder o-ring seal that goes there. And check to see if your pan is warped. I've had both of these things happen to me before.
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
Old Oct 21, 2000 | 03:04 AM
Live305's Avatar
it can also leak at the pump seal between the torque converter / pump junction.
also, check the tailshaft seal where the yoke goes in. i've had to replace that one.
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
