how do you install a tranny temperature gauge? (700R4)
Old Oct 19, 2000 | 10:46 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
how does a tranny temp gauge go in? i want to get one for my car, but not sure if i wnat to or not.
is it easy to install? does the tranny have to be dropped? is it inline with the tranny cooler lines?
what range should i get? i noticed there are a couple different temp ranges. the most common seems to be the 100-250 degree one. i assume this will work, will it?
if anyone has one of these, what one did you get? what do you reccomend? i think i am just gonna get one of teh autometer ones...not sure which one though.
thanks a lot.
-brian
1991 Camaro RS
Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner w/14"x3" K&N, Edelbrock TES Headers, Edelbrock Victor Series Water Pump, Accell Superstock Wires, Cap, and Rotor, MSD Blaster Coil, Hypertech Fan Switch & Thermomaster Chip, AC Delco Rapidfires, 3" Cat Back, Flowmaster 40 Series Muffler
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
Brian's 1991 RS
Central NY F-Body Association
z28boy@twcny.rr.com IM name: Z28 Boy
Old Oct 20, 2000 | 09:34 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I imagine you just tap a hole into the tranny pan, and screw the sensor in. Good time to drain the fluid & change the filter!
My Summit remote trans filter housing has a fitting that a trans temp gauge can be screwed into. I don't have one, so I left it plugged with their included brass fitting.
The gauge is probably electrical, so the hardest part would be running the wires from outside the car to the inside- use a grommet!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Oct 20, 2000 | 11:31 PM
ronterry's Avatar
Car: '94 Corvette
Hey 'Z28 Boy' I've got the Autometer Pro-Comp UltraLite 2 5/8 one. (Full race scenario)
I can answer a few questions, NO you don't need to remove the trannie.
My book on TH350's tells the best place to install the sender is in line on the return oil line at or near the firewall, away from any exhaust. Did you get all that ? If I remember right that is the upper line.
I havn't ruled out, putting it in the pan however.
No I havn't install my yet, since I need to figuer out which damn AN fittings I need...
If your Trannie Oil exceeds 250F, thats BAD.
I know varnish begins at above 250, @ 275 poly seals start to harden ect...
All I'm saying the 100-250 scale is OK.
Isn't she pretty ?
Ron C. Terry
'82 Trans Am
'81 Camaro Z-28
'94 Vette LT1 Coupe
Old Oct 21, 2000 | 03:46 AM
ronterry's Avatar
Car: '94 Corvette
Hey I found a link that might help on a pan installation...
http://neptune.spacebears.com/cars/stories/trgauge.html
Good Luck,
Ron C. Terry
'82 Trans Am
'81 Camaro Z-28
'94 Vette LT1 Coupe
rocn7roc
Sep 21, 2021 02:16 PM
camaro11j
Sep 19, 2018 08:49 AM
Reddeath210
Oct 6, 2015 08:20 AM
TreDeClaw
Aug 14, 2015 06:58 PM
drathaar907
Aug 6, 2015 04:20 PM
