TV Cable Corrector
Old Jul 30, 2008 | 01:05 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
TV Cable Corrector
Anyone with experience with the Sonnax AS1-01K TV Cable Corrector?
Is it worth to install this rather small device?
Or will it destroy my trans in the end..??
Old Jul 30, 2008 | 02:02 PM
Cat59's Avatar
Car: '87 IROC Z w/43,000 miles
Engine: 305 F code motor
Transmission: 4 speed auto
Re: TV Cable Corrector
https://www.thirdgen.org/forums/tran...able+corrector
Old Jul 30, 2008 | 04:21 PM
Old Jul 30, 2008 | 06:15 PM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
Wow, That looks really cool.
Old Jul 30, 2008 | 08:34 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
What effect does this thingy have on down shifts?
Old Jul 30, 2008 | 09:13 PM
tylersb350's Avatar
Car: 82 camaro sc
Engine: 355 SBC
Axle/Gears: ford 8.8 3.73
i ordered mine 3 days ago and just got it today. i put it on but i cant get my tv cable adjusted correctly. ive got and edelbrock carb with the geometry correct bracket mounted on the linkage. my shifts from 2-3 are hard but my 1-2 are still too soft. i made some one click at a time adjustments but thats the best i got it. any advice?
Old Jul 31, 2008 | 02:41 AM
Pro Built Automatics's Avatar
If you find that when the TV cable is overtight, that the transmission shifts better, but you cannot keep it adjusted this way because you lose the adjustment when you floor it because it pulls the TV cable out. This is what the Sonnax TV cable corrector is for. This is to allow more line pressure at the lower throttle openings, while not pulling the TV cable out at WOT.
Old Jul 31, 2008 | 01:57 PM
Clear, thanks!
My trans is shifting (much) harder, at somewhat higher RPM's, after mounting this Sonnax spring.
Does it harm the transmission in any way, do you think..??
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
