Help me figure out my 700r4
Old Oct 18, 2000 | 04:18 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
I put in a 700r in my camaro, it shifts great in all gears except OD. When i bring it above 2000rpm in 3rd, the shift to OD is an odd one. the rpms will stop climbing when its about to shift, sit at that rpm for a few seconds then finally lazily go into 4th.
the car continues to accelerate through the whole shifting process.
this is if i have a more-than-normal foot on the gas. if i am driving normally the tranny shifts fine. also, as soon as i want to start accelerating in od it immediatly downshifts into 3rd. is that normal??
is that rpm pause simply my TC locking up before shifting?
Old Oct 24, 2000 | 04:49 PM
89Iroc-ZL98's Avatar
Car: 1989 Chevrolet Camaro IROC-Z
Engine: 5.7L TPI
Transmission: WC T-5
Not sure about the poor shifting you are experiencing in your 4th gear but the downshift at full throttle is unfortunately normal. There are a few kits to eliminate this. I bought one from GM for the B4C police package but have yet to install it. (not sure how!!) If you havent changed your fluid in a while, give that a try.
Old Oct 25, 2000 | 12:30 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
89Iroc, the procedure's not that bad for the GM valve. What was the part # on that?
If you get an ATSG service manual, it has the same info that's in the GM/Helms "full" service manual. It also has a few service bulletins in the back. You would be replacing the "TV Sleeve", which can be done by just dropping the pan.
I bought my ATSG manual for $15 from Northern Auto Parts. Their website is at http://www.northernautoparts.com and it has their phone # on it. Give 'em a call. And do you have the part # of that GM valve?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
92firebirdguy
Sep 1, 2016 07:53 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
L0tuS
Oct 4, 2015 08:07 AM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Fronzizzle
Sep 8, 2015 12:10 PM
