tranny shift like crap when cold!!
Old Oct 25, 2000 | 10:26 AM
IROCSRULE's Avatar
WHen the car is cold in the morning and hasn't run all night. You have to drive it like 2-3 miles until it starts to shift right. Like, if you come to a complete stop, it won't go into gear at all, and you have to put it through the gears to get it to finally pick a gear again. But once the car's warm, and you drive 2 or 3 miles, it shifts fine. What could cause this??
Old Oct 25, 2000 | 12:02 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well as ya know, that's not good... start saving up some cash for a rebuild. In the meantime, do you warm up the engine before you leave? Warm up the trans at the same time. I usually let the car warm up for a min or two, then I put the car in drive for another minute or two, before I leave the driveway.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Oct 25, 2000 | 04:06 PM
88irocz28's Avatar
Car: 1994 Trans Am
Engine: 5.7L LT1
Transmission: 6-speed
I had the same crappy cold shift problem. I was about to prepare for a rebuild and voila, a tranny fluid change cured the problem. I guess it was probably crud builup blocking some valve or something. Downside of the fluid change - I'll probably still need the rebuild since now the tranny shudders before shifting out of second sometimes. Kinda scary...
'88 IROC 305 TPI
Gutted airboxes
160 degree T-stat
Advanced base TPS voltage
Relocated IAT sensor
Momo steering wheel
Ram-air setup coming soon
Flowmaster muffler
Taylor SpiroPro wires
Accel cap and rotor
92firebirdguy
Sep 1, 2016 07:53 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
