Need to readjust TV cable, how to firm up shifts..?
I just got a new 350 in my 86 transam...i remember i had the tranny redone a couple years back and the guy put in a vette servo....
i took it to another shop to get the seals redone on the tranny and they readjusted the TV cable to softer shifts and it shifts early.
Which way to I move the cable to make it shift later and harder. Thanks..
Gary
Gary
With the car off, push in the large vertical rectangle button on the side of the TV cable bracket. You stand on the driver's side of the engine to do this. It will require some effort to push. With the button held down, push the black plunger that sits on the TV cable toward the firewall. Let go of the button. Get inside the car and floor the gas pedal. Hard. You'll hear the TV cable mechanism ratchet, it will click several times. Your TV cable is now adjusted.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
supposed 'peanut cammed' car (yeah, right)
Built on Wednesday
[This message has been edited by MrJ (edited October 31, 2000).]
91 Trans Am WS6
Bright White
5.0 TPI auto
Trans Go shiftkit
Built on Wednesday
I do that and it wont ratchet in. i don't know why, so i have to have the button in and have someone else floor the pedal. is something wrong with that?
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
You skipped over a step that MrJ has in there: "Let go of the button." Instead of flooring the gas pedal, you can crank open the throttle body to WOT by hand. I do this so I can watch the TV cable re-adjust...
Greg Westphal
'87 IROC 305TPI/A4
Greg Westphal
'87 IROC 305TPI/A4
Z28/ZR1
10-23-2015 01:04 PM
TMZIrocZ350
10-07-2015 12:09 PM
