tranny question
Car: 1988 Camaro
Engine: 2.8l v6
Transmission: t5
tranny question
ok heres my problem im redoin a carb 350 to put in the maro this winter... ight now i have a 2.8l with a 5 speed tranny.. now i know the t5 will fit but it wont hold to my abuse so what kindaa tranny should i be lookin for... a t56 or what else does chevy have??? thanks
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
Re: tranny question
if the carb 350 is relatively stock and you get the World Class version of the t-5 it will probably hold for a good long time. The problem with the stock t-5's is if you put sticky tires or just get really good traction on a launch the amount of torque through the trans will actually break the casing.
i know of cars into the low 12's with t-5's and as long as you dont completly abuse them they can last a long time.
Otherwise your only stick opetions are a t-56, or a modified tremec tko-600.
the only place that sells the tko-600 modified for our cars is fortesparts.com. You can order from 5speedtransmissions.com or one or two other sites but it all comes from fortes so you might as well order directly from them.
basically they use the ford version of the trans (comes in GM and FORD) because the ford already has the right length input shaft for our application, there is a 1" spacer between the trans and bellhousing that adapts to the GM bolt pattern and it bolts right up to a t-5 bellhousing. Although a scattershield (blow proof bellhousing, lakewood and mcleod make them) is reccomended for any high perf application encase a clutch explodes.
Re: tranny question
I really can't ad anything to what Doug posted. His advice is right on the money. If you don't feel comfortable with a T5, then do as he said and look into either a T56 or a Tremec TKO. Thread
Thornburg
Aug 25, 2015 01:46 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
