What kind of.....
What kind of.....
rear end do i have in my 87' iroc z 305 tpi? What gears does that rear come with and is it a posi/limited slip?
Red 87'Z-28 350 tpi,MSD ignition 6al,gutted maf and airbox,
700r4 w/b&m shift kit and cor. servo
Car: Take
Engine: Your
Transmission: Pick
Check the RPO codes on the SPID label in the center console, or take a wire brush to the bottom of the axle tubes for a stamped alphanumeric code. Either one will tell you. The code on the axle itself is better in case the whole rear has been swapped before.
If you live in Southeastern US, check us out!
South East Thirdgen
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Boxed LCAs, 8mm Accel wires, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
South East Thirdgen
Savannah, GA
'97 Bonneville SSE
Gunner242
Dec 25, 2015 04:49 PM
