Posi mod????
Old Aug 6, 2008 | 07:53 PM
8t4marinator's Avatar
Car: 1984 Camaro Z28
Engine: 305 H.O. L69
Axle/Gears: 7.5" 3.73
Posi mod????
What does anyone think of taking the springs and retainer plates out of an eaton posi and putting them into an open diff?? Would this be of any benefit at all???? I catch posi for 4 feet and then it turns into a right tire free for all. Did the factory posi's have a clutch and spring setup in the differential, I changed the fluid in it recently expecting to see a limited slip unit of some kind (guy I bought the car from swore up and down that it was a limited slip car) and there were just spider gears.
Old Aug 10, 2008 | 06:40 PM
Re: Posi mod????
Any thoughts?????????
Old Aug 10, 2008 | 08:40 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Posi mod????
You cant just put springs into an open carrier. You need to replace all the parts to make it a posi.
Old Aug 10, 2008 | 09:20 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Re: Posi mod????
I don't think this is possible at all. The open diff's I've seen don't have any kind of "casing". The posi units are all encapsulated to a degree.
Old Aug 11, 2008 | 07:47 PM
Re: Posi mod????
Well, that's what I thought as well but I was given a carrier assembly out of another 10 bolt and it had the springs and retainer plates but no clutch packs inside of it. What I'm wondering is if by having the spring assembly in the carrier if it would take up any of the slip whatsoever.
Old Aug 11, 2008 | 07:54 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Posi mod????
What's keeping you from doing it properly?
Old Aug 11, 2008 | 07:58 PM
Re: Posi mod????
I have these parts
Old Aug 12, 2008 | 06:31 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: Posi mod????
so you have a posi carrier, but no clutch plates? If so, just try to get some clutch plates from somewhere.
KO1
16
Oct 15, 2015 05:00 PM
