Rear End swap
Old Nov 9, 2000 | 07:15 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
Rear End swap
i found a rear end out of an 85' monte carlo ss thats posi with 3.73 gears. Will it fit in my 86 Z?
Old Nov 9, 2000 | 07:58 PM
ede's Avatar
ede
don't think the monte has a provision for the torque arm. if you're talking just the carrier it'll fit.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 9, 2000 | 08:16 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The housing won't fit at all. The rear suspension is completely different. The gears might. Most g-bodies had 7.5 gears but some are 8.5. If it's a 7.5 diff than you can swap the gears and carrier over into the f-body diff.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car
91 454SS daily driver
95 Homebuilt Harley
Old Nov 9, 2000 | 09:41 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
it is a 7.5" so i should be able to swap parts on them right?
Old Nov 10, 2000 | 12:42 PM
badbird88's Avatar
If your 86 Z has 3.08 gears or lower then the 3.73 gears will probably not fit unless they are aftermarket gears made for the 3.08 and 2.73 gear carriers. Richmond makes these gears for the 3.08 housings that are lower than a 3.08 (lower meaning 3.42, 3.73, ect). Stock GM 3.73 gears will only fit in a housing that came with 3.23 or lower gears.
1988 TA 300+hp 350 w/ TBI and Holley TB unit, Holley projection intake,
WC T-5, 3.42 gears w/ Auburn posi. MSD 6A, edelbrock TES headers, dynomax 3" cat and cat-back system, ACCEL coil, polyurethane bushings all around, aluminum driveshaft, Mr. Gasket open air cleaner.
1993 S-10 w/ 4.3L V6 TBI, slightly bigger cam, Mild polish job and 3 angle valve job on heads, Edlebrock TES headers, Dynomax cat back, MSD 6A, ADS chip
2000 Kawasaki KX 125
Old Nov 10, 2000 | 05:11 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
is there a code somewhere that will tell me what gear is in there now? i think they are 2.73 gears but im not positive.
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
