trans mount???
Old Nov 7, 2000 | 09:39 AM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
trans mount???
I broke my 3rd trans mount in 1 1/2 years the other day. I had the others replaced by a mechanic. I want to do this one myself. Is it as easy as pulling up on a ramp (I only have one wooden ramp though but I can reach everything under neath the car fine) and undoing mount bolt and putting the new one in and bolting it up?
1987 Iroc 350
GTS headlight/tail light covers
Camaro SS Wheels w/Sumitomo HTR ZII 275 rear, 255's in front
K&N filters
Adjustable Borla cat back
Large tube runners
ported plenum
Holley afpr
SLP 1 3/4" headders (not installed yet)
FUTURE GOAL:
To go really F'in fast!!!
Some pics of it at
http://albums.photopoint.com/j/Album...949&Auth=false
Old Nov 7, 2000 | 11:40 AM
chris1roc's Avatar
It's really easy. Jack the tans take the crossbar nut off then take the trans mount bolts off inbetween the crossbar and trans and it comes right out.
88 iroc-z
305 tpi/ads chip/k&n/shift kit/HP stall converter/flowmaster/homemade ram air/160 thermostat
Old Nov 7, 2000 | 11:42 AM
chris1roc's Avatar
did you have to do anything special to get the SS wheels to fit? Or did they fit right on?
Old Nov 7, 2000 | 01:38 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Wooden ramp? That sounds a bit scary... how about jackstands? And how about that indestructible Energy Suspension polyurethane trans mount? I went through 3 in 2 years until I got the ES piece. It's $26 through http://www.summitracing.com , if it's not on their website, give them a call.
You put a piece of wood across the trans pan width-wise, put a jack under that piece of wood, and raise the trans about an inch. The rest is as chris1roc said.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Nov 8, 2000 | 09:57 AM
Transmission: 4L60e
Axle/Gears: 9 bolt
Yeah wooden ramps! I made one out of some long boards that were like 12" wide and stacked them and nailed them together. Its a good ramp. I dont trust metal ramps or jack stands very much. Only made one though.
I was probably going to go with that es mount since everyone has had good luck with it.
chris1roc, I needed spacers for those SS wheels to fit.
Old Nov 12, 2000 | 05:16 PM
Transmission: 4L60e
Axle/Gears: 9 bolt
I haven't had a chance to fix my mount. An I hurting the car by driving it with the broken mount?
1987 Iroc 350
K&N filters
Large tube runners
ported plenum
Holley afpr
FUTURE GOAL:
Some pics of it at
Old Nov 12, 2000 | 07:45 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
I broke 5 in like 3 months,then I went to autozone and purchased a ten dollar lifetime warrantied T-mount,no trouble since.
althoug my car is an '84 TA th700r4 the only mount that will fit is for an '83 camaro,whats up with that?
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
jharrison5
Aug 19, 2015 05:53 PM
timonator
Aug 11, 2015 09:56 PM
