Can you narrow a 10 bolt rearend in a 3rd gen?
I was wondering, is it possible to narrow a 8.5 10 bolt rearend say out of a 2nd gen f body? I think i read somewhere that they are a little wider/narrower. I know the spring perches and everything are different. I didnt know how much trouble this would be. I dont think my stock rearend is gonna live behind my engine combo. Thanks. LilJay
Wide Open Till You See God.....Then Brake
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You could, but you would have to move all the mounting hardware such as spring perches, LCA mounts and panhard bar mount over to the 8.5 diff. That's the easy part. You then have to find some way to attach the torque arm. The only other way is to install ladder bars or a 4-link.
If you're going to go through all that trouble anyway, why not modify a 12 bolt or a 9" instead.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car
91 454SS daily driver
95 Homebuilt Harley
[This message has been edited by Stephen 87 IROC (edited November 12, 2000).]
Best 60 foot: 1.662
87 IROC bracket car
95 Homebuilt Harley
ambainb
Apr 25, 2016 09:21 PM
