700R4 To TH350 Swap
Old Aug 10, 2008 | 04:06 PM
gearhead18's Avatar
700R4 To TH350 Swap
Hey guys, my 700r4 finally went out and i had a 350 laying around. I bought the B & M swap kit and everything for the torque arm. Only problem is that my drive shaft is too short. I did a search and I couldn't find any info on it for this. I was wondering if there were any other vehicles drive shafts that would work with the swap or should i just have mine lengthened and balanced. any info would help, thanks
Old Aug 10, 2008 | 06:47 PM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
Re: 700R4 To TH350 Swap
If its a 6" tail shaft a driveshaft from a 82 camaro or firebird with a TH200c or 4-speed will work.
Old Aug 10, 2008 | 07:26 PM
gearhead18's Avatar
i read about that but i was wondering about any other GM Models other than the Camaro or Firedbird with the TH200, thanks for the tip though
Old Aug 11, 2008 | 12:39 AM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
I would slide the slip yoke into the back of the tranny all the way then pull it back out 1". Measure from center of u-joint on the tranny yoke to center of u-joint on the diff yoke. That's the length you need, I think it 41". then call your local wrecking yard they should be able to find you something.
Old Aug 11, 2008 | 08:00 AM
gearhead18's Avatar
thanks but afterdealing with all my junkyards around here they are too lazy to do anything, not to mention the slim pickings in the yards. thanks for info but i guess i will just take my driveshaft to the machine shop and lengthen it. another question on this.If i have the 6" tail shaft, then the drive shaft will need to be lengthened 3" correct?
Old Aug 12, 2008 | 10:56 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
not really sure but instead of going to the machine shop to have them lengthen anything call muscle motorsports and just get a used nascar spicer driveshaft after you know the correct length it can be a little different for every car. They are around $50 and shipping the last I checked unless they raised the price but I don't think so. You should also replace the U joints.
camaro11j
Sep 19, 2018 08:49 AM
LittleFranks
Sep 17, 2015 12:22 PM
C409
Sep 1, 2015 03:42 PM
spaigo
Aug 21, 2015 07:46 PM
TreDeClaw
Aug 14, 2015 06:58 PM
