Were can I drill hole to mount sensor?
Old Nov 15, 2000 | 02:59 PM
Biochem's Avatar
Car: 2002 SOM z28
I got a tranny temp gauge and it comes with a 3/8" and 1/2 plug with a 1/8" hole through its center for the sensor to screw into.
Are there any holes that are any of those sizes all ready drilled into the housing of a 89+ 700R4 so I don't have to go into the pan?
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock... all the suspension stuff... 9-bolt posi disk is in... K&N filter... 93 octane...
-=ICON Motorsports=-
Old Nov 15, 2000 | 07:17 PM
ronterry's Avatar
Car: '94 Corvette
Not that I know of. You can tap the pan, say in the front, but you need to make sure it clears on the inside.
Outside of that you can buy a AutoMeter transmission manifold #2286 for 3/8 & #2287 for 5/16. This allows you to tap the oil line.
Good Luck,
Ron C. Terry
'82 Trans Am
'81 Camaro Z-28
'94 Vette LT1 Coupe
Old Nov 15, 2000 | 08:18 PM
ede's Avatar
ede
i just bought perma-cool remote trans filter kit and it has a tapped hole for a temp gauge. cost about 30 dollars for the kit w/filter.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 16, 2000 | 11:38 AM
IROCET's Avatar
Car: 88 IROC-Z (Sold)
Engine: 5.7L
I put a B&M drain plug in my tranny last summer. It is towards the front, where there is no interference with anything inside. It made it so easy doing oil changes on that thing. Anyway, two months ago I put a temp gauge on it. It was quite convenient because the sensor screwed right into the nut for the drain plug. Killed two birds with one stone, and never had a problem with it leaking. Good luck.
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
88 IROC-Z -- 350 L-98, 700R4, Flowmaster, K&N, MAF Sceens Gone, Airfoil, March Pullies, Comp Cams Magnum 1.6 Roller Rockers, Accel U-Groove Plugs, Accel 8.8 mm Wires, Hypertech Cap & Coil, Hypertech Chip, Hotchkis Strut Tower Brace, One Loud Stereo!
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
aaron7
Aug 17, 2016 06:02 PM
Elliswon
Aug 10, 2015 12:33 PM
