transmission mount
Old Aug 12, 2008 | 01:20 PM
antosh's Avatar
Car: 1991 camaro z28
Engine: 5.7 TPI L98
Axle/Gears: stock
transmission mount
here the problem i have bought three new mount in a short time and have broken them all its on a 91 z28 with the l98 engine and the 700r4 tranny few modifications such has new exhaust msd ignition and a shift kit. i would like to know why is it breaking so much is there a better mount that i could get that would just fix this problem??
Old Aug 12, 2008 | 03:39 PM
Doc_G's Avatar
Car: 87 Trans Am
Axle/Gears: Not enough
Re: transmission mount
what type/brand of mount are you currently purchasing? Also what type of driving are you doing? I.E. are you putting it in neutral and revving it up to drop into a gear, do you do alot of burnouts? Possibly the shift kit is shifting too hard for the type of mounts your currently using.
Old Aug 12, 2008 | 03:45 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You don't say if you were using OE rubber or after market poly. I've never broken the poly.
JamesC
Old Aug 13, 2008 | 12:00 AM
antosh's Avatar
Engine: 5.7 TPI L98
Axle/Gears: stock
well its just the oe rubber and i do drive it that hard at all never rev it up in neutral and drop it in gear and sometimes i will be a little heavy on the gas
and where would you find the aftermarket poly mount?
Old Aug 13, 2008 | 06:49 AM
JamesC's Avatar
Energy Suspension makes what you need. Check with your local auto parts store, Summit, Jeg's, or with Spohn, a board sponsor.
JamesC
jhawkeye
May 25, 2022 06:33 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Vintageracer
Jan 10, 2020 05:33 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
theshackle
Aug 23, 2015 03:49 PM
