4:11 gears in an 85
Old Nov 19, 2000 | 07:51 PM
G's Avatar
G
4:11 gears in an 85
me and my dad got a good deal on a 79 camaro with a 350 th400 tranny and a rear end with 4:11 gears. will the rear end fit in my 85 or do i need something else. will i also need to shorten or lengthen my stock drive shaft.
Old Nov 19, 2000 | 08:29 PM
ede's Avatar
ede
won't fit. the 2nd gens used a differant rear than the thirdgens, plus you have the torque arm to deal with.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 19, 2000 | 08:31 PM
G's Avatar
G
can i put the gears in my rearend
Old Nov 19, 2000 | 08:33 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The gears themselves won't work in the third gen. Wrong size
The diff will fit, size wise, but that's all. The 79 uses leaf springs. 82-00 use coils and a torque arm. You would need to move all the mounting hardware from the third gen diff over to the 79. Then you need to find some way of mounting the torque arm. It's the torque arm mounting that makes diff swapping into a third gen almost impossible. Aftermarket 12 bolts have a mounting pad cast into the housing and ford 9" diffs have an available mounting bracket that just bolts on.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car
91 454SS daily driver
95 Homebuilt Harley
Old Nov 19, 2000 | 08:38 PM
G's Avatar
G
schould i just sell the rear end and buy a ford 9 inch
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
