cant figure out what is clunking...
Old Aug 14, 2008 | 12:24 PM
brodysZ28's Avatar
Car: 1983 Camaro Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: Strange S60
whenever i give sudden gas or let off suddenly, it feels like the rearend has a bunch of play and wants to turn right off the car. you can feel it in the floorboards when it does it too. i had a loose sway bar end link, replaced that, and no difference. what could this be? everything looks fine underneath the car. would a driveshaft do that? what could it be?
Old Aug 14, 2008 | 05:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: cant figure out what is clunking...
Broken tranny mount?
Old Aug 14, 2008 | 05:43 PM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
differencial mount?, LCA Bushings shot?, Possible U-joint (most likely not thought because they usually make clunking while driving to)
Old Aug 15, 2008 | 12:06 AM
lewandom's Avatar
Car: 84 Z-28 Camaro, 2022 Chevy 2500
Engine: 383
tranny mount...get a prybar and pry between the tranny and crossmember, if the rubber seperates the mount is bad....get a poly one the rubber ones suck
Old Aug 15, 2008 | 11:04 AM
brodysZ28's Avatar
Engine: 383
i dont think its a trany mount, its been off and on twice and is still doing it. its is also a poly mount. where is the differential mount and LCA bushings?
it does clunk while a am driving, just not all the time, lk only when i shift or am at low rpms, or sudden throttle.
Old Aug 15, 2008 | 07:24 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Check the trq arm bolts! My friends car kinda clunked, looked under there, and one of the bolts was missing, the other one I could spin by hand
Old Aug 15, 2008 | 09:54 PM
brodysZ28's Avatar
Engine: 383
the bolts on the rearend or tranny? yea the front one was missing but i put a new one in... i will check them again though.
the only other thing i noticed was the lk scissor bar type deal which runs parallel to the axels has a small bend in it. to me it looks like it wouldnt affect its job, but maybe thats it...
Old Aug 18, 2008 | 06:44 PM
brodysZ28's Avatar
Engine: 383
so i was assuming that the garage put the tranny mount bolt in, but i have learned over the last few years not to assume anything.
there was no bolt going through the crossmember into the mount.
i am bassically guessing and checking to figure out what size and thread it is... does anybody know off the top of their head?
thanks guys.
sheachopper
Jul 31, 2019 11:27 AM
RedLeader289
May 28, 2019 01:47 PM
mrbird
Oct 20, 2015 03:43 AM
aaron7
Sep 30, 2015 09:15 AM
Zell1luk
Sep 29, 2015 10:36 AM
