10 Bolt Drum, Disc, Same Housing?
Old Nov 21, 2000 | 05:40 PM
MJG's Avatar
MJG
Are 10 bolt housings equipped with drum brakes the same housing as disc equipped housings? I have a 10 bolt with drums, will the caliper brackets from a 10 bolt or even a 9 bolt match up to the ends?
Your comments are greatly apreciated
Old Nov 21, 2000 | 07:44 PM
ede's Avatar
ede
i think, but don't know for sure, that the backing plates are differant for disc and drum.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 21, 2000 | 09:55 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
The housing itself is probably the same. But you can't easily swap the disc setup over to tha drum brake housing. The axle hubs have a different diameter (larger for drum version). The backing plates for both are welded to the housing. I have heard of some people with welding equipment doing the swap. But it definitely isn't an easy bolt-in swap.
hectre13
Dec 11, 2023 08:14 AM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
