Stock Shifter
Old Nov 23, 2000 | 10:48 PM
Stell1579's Avatar
Stock Shifter
i have a camaro and like the way the firebird auto shifter looks (w/thandle)
is there a way to interchange the ****? if so how, i have tried to get the one of the 2 types in a junk yard. or does the whole asembly have to be swapped?
-Stell
1988 IROC 305TPI MINT!!
Mods= Accell SuperCoil, MSD 6A, Ported Plenum, No MAF Screans , K & N, 160 Thermostat+ Temp Switch, Relocated MAT, Cold Air
Old Nov 23, 2000 | 11:37 PM
Black Missile's Avatar
The Firebird T-handle shifter has a external u-shaped pin that secures the shifter handle on the front-side.
The Camaro shifter handle has an internal snap-ring located below the selector push-button. You may need to get the Firebird shifter shaft to mount the Pontiac style shifter.
Have you considered the "rectangular" style shifter handle from the '90-'92 Camaros?
1989 Firebird GTA: black on black 5.7 liter (N10 dual exhaust) with T-tops and leather.
Old Nov 24, 2000 | 01:17 AM
Danny P 86Z28's Avatar
You will have to swap out the shifter mechanism along with the ****. Try looking in a junkyard. I got mine at a Pick A Part and I definitely like the trans am shifter better than the camaro shifter.
Old Nov 24, 2000 | 06:53 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Hmmm, I had no problems mounting a Firebird shifter handle onto my IROC's shifter mechanism. Both the original IROC and the Firebird shifter handles were held in by the U-shaped pin on the front side. Took me all of 2 minutes to swap from one to the other. I definitely like the way the Firebird handle feels and looks better than the IROC one. Makes manually shifting a little easier too.
Greg Westphal
'87 IROC 305TPI/A4
BewleyBizzIROC
Feb 3, 2020 09:52 AM
Genopsyde
Oct 7, 2015 08:35 PM
NBrehm
Aug 25, 2015 11:49 PM
neekolzun
Aug 24, 2015 04:59 PM
Dialed_In
Aug 20, 2015 01:45 PM
