3.73 Gear Swap
Old Nov 26, 2000 | 07:31 PM
f.benvenga@att.net's Avatar
3.73 Gear Swap
Hey folks,
Where can I find the procedure for swapping the speedo gears for a 3.08 to 3.73 rear? Is it simple? Can someone please tell me how to do it? Thanks.
Frank
Old Nov 26, 2000 | 07:37 PM
ede's Avatar
ede
the gear for the speedo is on the end of the cable where it goes inside the trans. just unbolt the cable and pull it out and you'll be looking at a plastic gear. that's it. slides right off.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 26, 2000 | 09:54 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
That is if you only have to change the driven gear. If you have to change the drive gear (or both, as you often have to do with an extreme gear change), then you have to remove the tail on the end of the tranny and swap the drive gear on the output shaft.
You don't state your tranny but I will assume the procedure is relatively similar for both. Also, there is a sleeve on the output shaft that often must be changed too.
I strongly urge you to get a good shop manual if you have to replace the drive gear.
hectre13
Dec 11, 2023 08:14 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
Dialed_In
Aug 20, 2015 01:45 PM
mizz0313
Aug 12, 2015 06:45 AM
