Th 350 which fitting is in and which is out?
Old Nov 24, 2000 | 06:17 PM
ede's Avatar
ede
for the trans cooler lines?
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 26, 2000 | 07:38 PM
ede's Avatar
ede
BTTT
1st & 3rd
Old Nov 27, 2000 | 12:42 AM
spud's Avatar
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
? I just assumed top was out and bottom was in.
Boy, I am a bunch of help.
My tranny stays cool this way, but I don't know if i'm right or not.
Sorry
John
82 Firebird,355,Cam 224/234, .466/.488,TH350 Tranny,650 HolleyDP,Hooker Headers(I.E. POS) Manual steering
Best 8th et 8.62@80mph.
Old Nov 27, 2000 | 01:01 AM
mtx28's Avatar
ill throw in my 2 cents... as far as i know, the return line is the bottom, but could be wrong
Old Nov 27, 2000 | 05:09 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Here's what I did, but it's a little messy if you do this by yourself...
Disconnect both lines at the radiator.
Start the car and put it in drive for about a second.
Which ever line the fluid gushes out of is pressure.
If you have a friend with you it's a little easier but still messy. HTHs
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
Old Nov 27, 2000 | 06:41 AM
El Guapo's Avatar
Most companies just use gravity to expose the liquid (antifreeze, trans-cooler, etc) to the cooling air, therefore your bottom is your return.
Clayton
Old Nov 27, 2000 | 05:18 PM
ede's Avatar
ede
well it's a little more complicated then that. my trans is laying in the garage floor right now. i need to know what's in and what's out to run a line to a remote oil filter and then to a sepereate trans cooler. i'm running stainless line and an fititngs and as much as they cost i don't want to get it wrong, plus i want my filter and cooler to work like they should.
1st & 3rd
Old Nov 27, 2000 | 06:47 PM
mtx28's Avatar
ede... i just replaced the return line in my 74 camaro with a TH400 tranny.. in the restoration catalog the lines as a pair are 80 flippin dollars, so i was talkin to my brother in law about it, who has a few more years experience than i do, he laughed and said 'just go down to pep boys and get a pair of the lines for 5 bucks' so yea, the gravity idea makes sense, the bottom is the return line(as in the radiator bottom line and the bottom on the tranny). i got a 60" line, but its kinda long so i had to make a few extra bends so it'd fit, dunno if the set up is the same on the TH350(the lines being on the same side of the trans and whatnot) but you might wnat to get the 50" line, your choice
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
wruiz
Aug 13, 2015 09:07 PM
armybyrd
Aug 10, 2015 09:23 PM
milk
Aug 10, 2015 06:26 PM
