Are all torque arm bolt hole this way?
Old Aug 19, 2008 | 09:08 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I just bought a rear end from a junkyard (posi 9-blot with what I was told was 3.45 gears but after pulling the cover they are 3.27) and after pulling off the piece of torque arm, I found the holes were oblong. I took some measurements and the are roughly 15.6mm front to back and 14.4mm side to side top. Now is that normal? I was told the tolerances might be like that from the factory to make assembly easier, and I was also told the previous owner was probably doing a lot of whole shots and ended bending the bolt holes on the rear end housing... but wouldn't the metal crack before it deformed? Anyway, here is a picture of what I'm talking about...
Is this rear safe to use in my car?
Mike
Old Aug 20, 2008 | 02:18 AM
noahTHEpurdy's Avatar
Car: 1992 Pontiac Firebird
Engine: 3.1
Axle/Gears: 3.42 Auburn Posi
Re: Are all torque arm bolt hole this way?
I'd be really leery about that. On both of my rear's the holes are not oblong.
Old Aug 20, 2008 | 06:25 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Either way it's not going to make much of a difference as long as the surfaces are nice and flat should work fine.
Old Aug 21, 2008 | 05:06 PM
Car: 1987 IROC-Z
Transmission: TH350
Does anyone else have an opinion?
Old Aug 22, 2008 | 02:26 PM
blackblazer717's Avatar
Car: 92 Rs
Engine: 4 Bolt "010" 383
Transmission: 700R4 trans brake Hughes 3K convert
Axle/Gears: BW 9Bolt 3.70's
looks to me like the PO, before the junkyard got the car, did some trans work or something where the torque arm was required to be removed and when it was reinstalled the bolts loosened up for whatever reason, and the car was drivin with them loose for a while and the bolts caused the housing to de-form... from the axle "trying to wind", it may be ok but once you get the car back together CHECK THE PINION ANGLE and make sure its correct, and also, torque the two torque arm bolts to 100FT-LBS......... no less, and dont use a impact gun.....
good luck
LUKE
84z96L31vortec
Aug 20, 2017 12:16 AM
zayne0
Aug 24, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
