rebuilding a 200
Old Nov 24, 2000 | 04:17 PM
82z's Avatar
82z
rebuilding a 200
I want to rebuild a 200-4r in my auromatics class and I was wondering who makes a quality, complete (everything but steels) kit. I understand Napa and B&M are no good but who is? What is a good price for a guaranteed rebuildable core, ~150? Also what can I do to increase the torque capacity of this underdog tranny? Thanks
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Old Nov 27, 2000 | 06:38 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
I think that if you do rebuild that tranny, use another one in your car!!! I have a 200 with a shift kit, (I bought it that way) and after about three years or so I have no second gear. Oh yeah, my mods are K&N and that's it. Although maybe the R4 means more heavy duty as well as an overdrive?
just a thought.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
Old Nov 29, 2000 | 02:08 PM
82z's Avatar
82z
What does your fluid look like? Is there a lot of clutch material or any metal? I think 200 is the relative torque rating of the tranny which is much less than a 700 but I want a 200 anyway. The benefits include(700vs.200) higher first and overdrive gears which is my primary reason but every 200 also came with a lockup torque convertor. I have no idea why the 4r is switched compared to a 700-r4.
Old Nov 30, 2000 | 10:47 AM
Bryant's Avatar
The 2004r can be built to withstand a lot of abuse. The Buick Grand National guys have been running them into the 9's with some beefed up parts and easily run in the 11's with stock units. The stock GN trannies had a few upgrades from the factory, but I believe it was mostly in the valve body. You might want to post your question over at their site:
http://www.turbobuick.com/
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Night rider327
Oct 9, 2015 09:25 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
ironbmt
Sep 27, 2015 06:00 AM
