Tranny's still messed up...
Well after a full night of working on the car (mostly the valve body of the tranny) to my "surprise" the symtomps didnt change one bit! It still wont shift out of first. LOL I took the valve body down, cleaned it, made sure all the valves move freely. I forgot to hook the manual valve "plunger" to the cam of the shifter cable so I had to take the valve body down again, wrestle with it for another hour to try to get the hook on it (that m****er is heavy, especially with that little clearance under the car).
However now it finally shifted into third, a very faint shift. I'm begging to think it's the fluid passage that goes to the governor that's clogged big time. Or maybe the screen that's supposed to be installed over the hole. Anyway, I just wanted to get some opinions because it's not like I'm gonna go trough the hell of taking that valve body again. Could it be that driving around somehow unclogged or unstuck the governor ?
p.s. I'm talking about a 700-R4
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
http://www.truspeed.org/Members/Chev...dmondIndre.htm
92 Z28 L98 350
Car: Take
Engine: Your
Transmission: Pick
What happened to second?
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass,
SSM SFC, Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
South East Thirdgen
Savannah, GA
'87 Trans Am
TB Coolant Bypass,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
'97 Bonneville SSE
Well not it has 2nd. It will switch from 1st to 2nd at 3000 rpm (a veeeery soft shift) then the RPM go down for a couple seconds like it shifted into third, then right after RPMs quickly start to climb like it's back in 2nd. So I guess I lost third and forth.
Do you think 800 bucks is a fair price to get tranny rebuilt with everything upgraded in it and designed for racing ? There's s a shop here in Vegas that does em for the racers in town and they stand behind their trannys when they break. They say the warranty covers the tranny even if I race it, if THAT's what I tell em I want it built for to begin it with.
92 Z28 L98 350
92 Z28 L98 350
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
