Automatic to Manual Conversion Peeps
Old Aug 21, 2008 | 08:20 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
I've already done the conversion and have like 2000 miles on the car since then.
One problem tho. The clutch master was put in the exact same spot on the fire wall as it was in the 5spd original car but it seems ( well is ) crooked to one side a bit.
The pushrod is slightly bent and i know eventually it'll cause issues.
As well the clip for the brake pushrod hits the clutch rod when i depress the brakes without pushing the clutch.
how can i remedy this seeing the the set up is already been drilled and installed?
maybe shimming the clutch master?
Old Aug 22, 2008 | 06:36 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Re: Automatic to Manual Conversion Peeps
ttt
Old Aug 22, 2008 | 08:12 PM
1986Sleeper's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Transmission: TH350
Axle/Gears: Stock
I just pulled my 5spd setup and sold it today. I noticed that my master was a little crooked to, and the car had 130,000miles on it without problems. If anything use some washers to shim it.
Old Aug 22, 2008 | 08:29 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
thats what im thinking....
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
Magman
Sep 12, 2015 11:55 PM
