Lock up Vs. Non Lockup
Old Nov 30, 2000 | 08:59 PM
brockrodgers's Avatar
Car: YTG Camaro
Engine: 383
Transmission: TH-350
Looking to switch to apx 2400 rpm stall. I currently run high r's down the freeway and I do a lot of highway driving. The 3.73 rear gears and No OD don't help. I am leaning toward Lockup but not 100% how performance is effected. Also Trany cooler or not? Any help is awesome!
'84 Camaro 327ci Bored .030 over w/ 5.7" stroke. The good 327! 3.73 geared Auburn Limited Slip Diff. FlowMaster Muffler w/ Shortie Headers. TH-350 Built Trany Underneath B&M Mega-Shifter. Many Engine compartment Dress Up Mods. Edelbrock High Flow Water Pump w/ Flex-a-Lite Cooling Fan.
It is still under construction @ www.iserv.net~brodgers
Old Nov 30, 2000 | 10:09 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Go with the lockup,if ya don't have a lock up it will slip more in fourth gear and turn more RPM's.For sure go with a trans cooler,any time you add a stall you will add more heat to the tranny.
Old Dec 1, 2000 | 08:15 AM
82camaro's Avatar
Car: 82 camaro SC
A lock-up converter won't work with a th350. You need the th350-C. If the tranny didn't come with a lock-up converter stock, you can't install one and have it work now.
A tranny cooler will extend the life of your tranny, especially with a higher stall converter.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Dec 1, 2000 | 11:36 AM
Car: YTG Camaro
Engine: 383
How do I know if I have a lock up or not already? And how do I know if the trany is a TH-350 C? This is the first that I have heard of such a thing.
Old Dec 1, 2000 | 11:57 AM
82camaro's Avatar
Car: 82 camaro SC
I th350C will have an electrical plug in somewhere on the tranny to control the lock-up. A computer usually controls this, but a toggle switch can be used as well as a vacuum switch.
82camaro
Old Dec 1, 2000 | 12:04 PM
82camaro's Avatar
Car: 82 camaro SC
You have a 327 w/5.7 stroke? Or do you have 5.7 inch rods.
82camaro
Old Dec 1, 2000 | 06:51 PM
Car: YTG Camaro
Engine: 383
95% sure it is 5.7" stroke. They call it a large journal 327. If I bored it again and droped in a 400 crank it would be a 383. But I am not an expert. I was told by a couple people that it is a rare block.
About the trany I am positive there is a vacume line running to the trany. So that must mean I have the TH350C w/ a Lock up convertor.
Old Dec 1, 2000 | 09:34 PM
82camaro's Avatar
Car: 82 camaro SC
A 327 has 3.25 stroke. The large journal isn't much better than a small journal. It may be a little bit stronger, but 327 small journal engines will take alot of abuse. The 5.7 is the rod length. A 350 has a 3.48 stroke. I 383 'stroker' has a 3.75 stroke.
82camaro
Old Dec 2, 2000 | 08:16 PM
Car: YTG Camaro
Engine: 383
Where Is a good site for engine specifications numbers like ci, bore & stroke #'s. What about casting & block i.d. #'s, info like that is awesome for getting some history on my engine!
Old Dec 2, 2000 | 08:34 PM
82camaro's Avatar
Car: 82 camaro SC
http://www.mortec.com is a good site.
82camaro
Old Dec 2, 2000 | 09:54 PM
CamaroMike's Avatar
A 327 has a 4" bore and a 3.25" stroke! If you had a 5.7" stroke that would be one tall block! ROTFLMAO! I'm sure they are 5.7" rods.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
91 Firebird 5.0L TBI
ASE Certified CHEVY DEALER Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old Dec 4, 2000 | 07:33 AM
Car: YTG Camaro
Engine: 383
Thanks for the help. I will correct my signature to reflect the recently learned information.
jrdturbo
Mar 31, 2016 02:58 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
kkirch15
Sep 30, 2015 04:44 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
