Clutch not disengaging
Old Aug 23, 2008 | 01:56 PM
rads84n94camaro's Avatar
Car: 94 Camaro RS. 84 Z28 350 T5
Engine: V6 & V8
Transmission: Automatic & Manual
Alrite so i just got done putting a t5 in my 84 camaro. I used the hydraulic clutch setup but for sum reason it doesnt want to disengage. The transmission is from an 91 camaro. Can anyone give me any advice as of wut mite be the cause of it not engaging?
Old Aug 23, 2008 | 03:16 PM
Whips89RS's Avatar
Car: 72 Malibu, 89 RS & 04 Z71 extended
Engine: (2)350's & 327
Transmission: auto/T5
Axle/Gears: 4:11, 2:73 & 3:73
Re: Clutch not disengaging
I'm having the same problem. From what I've been reading try bleeding the hydraulic unit(search the posts for instructions) and check to make sure the pilot bushing is in right. I bled it a few times with no luck. I took it all apart and am in the proccess of putting a new clutch fork and pivot ball in. The ones I got were worn pretty bad. I took everything off and re-aligned it. Hopefully it will work when I am done.
Old Aug 23, 2008 | 06:36 PM
Whips89RS's Avatar
That worked. I put the new parts in, re aligned everything and she works. Shifts nice, I love it. definitely glad I made the swap.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
