10 Bolt drum to 10 Bolt disc,, questions
Old Dec 7, 2000 | 11:01 PM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
Here's what i would like to do, and please give me your opinion on what i should do.
My 92 Camaro has rear drums, a T5, and originally had the 305 TBI.
What ratio do i have? (i'm thinking 3.08)
What size ring gear? 7.5", 8.5"....?
Axle splines?
Posi?? (if it is, it sure don't act like it)
Ok, should i rebuild it with like a Auburn limited slip diff or a powertrax performace locker?
I want 3.73 gears, posi and disc brakes. I will probally get Baer brakes in the future. I'm NOT building this car for the strip but for the street and maybe some autocross.
Should i get different spline axles?
Any advice would be greatly appreciated,
Dave
92 RS
350
Street & Performance MPFI
TFS heads
Crane Rollers
MSD Digital 6 Plus
24lb injectors
ZZ3 cam
Edelbrock Headers 1 5/8
3" Exhaust
Hi Flow 3" Cat
stock T-5
stock rear 3.08
koni yellow adjustable front
twin turbo glass hood
T-tops
Auto Meter Ultra Lite Series 2 5/8 gauges
Color: Teal Green
Old Dec 8, 2000 | 12:10 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Your 92 305 TBI stick car came with a 3.08 open 7.625" 10-bolt rear end, with 28 spline axles. If you want to keep it, you can get an SLP take-off torsen posi for $100, plus a set of 3.42 gears from a 4th genner who upgraded, along with the correct speedo gears (purple 7 tooth, white 19 tooth) and be in business. If you want disc brakes, you'll have to swap in a new rear end, preferably one from a 90-92 car. They'll be either 3.23 ratio from an automatic, or 3.42 ratio from a stick. The 3.42 ratio is preferred, as GM doesnt make speedo gears for a 3.23 5-speed car for 90-92. You'll need another solution, like a cyberdyne box, for that.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Dec 8, 2000 | 02:52 AM
chevyboy07 91's Avatar
Ummmm, correct me if I'm wrong but a 4th genner's gears won't fit his rear b/c it's a 2 series carrier and the gears only fit 3 series carriers. But the takeoff posi is good to go
Old Dec 8, 2000 | 08:59 AM
327 firebird's Avatar
You should have a 7.5" and 28 spline axles. The 28 spines are the best factory ones available. For the gear ratio you your best and eaisiest bet is to look at your RPO codes in you glove box and use the decoder on this web site to find out. It will be a code like GU and then a number
Old Dec 8, 2000 | 04:13 PM
Kevin91Z's Avatar
I said get the SLP posi AND the 4th gen gears.
And the later 10 bolts are 7.625" in diamter for the ring gear. The earlier ones are 7.5". I think the switch was made in 85, but I am not sure on that.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
355tpipickup
Aug 25, 2015 12:54 AM
redmaroz
Aug 16, 2015 11:40 PM
