91 RS has 10 bolt 7.5" or 7.625"? 28 spline? Right
Car: A Camaro
Engine: Weak
Transmission: Weaker
is the rearend on an RS a 7.5" or a 7.625"? I've seen both answers on this board. It's 28 spline correct?
should be a 7.625" and yes it is a 28 spline. If you pull the cover off and rotate the gears you should see teh gear info on the ring gear and it will tell you if it is a 7.5" or 7.625" but it should be teh 7.625".
1988 TA 300+hp 350 w/ TBI and Holley TB unit, Holley projection intake,
WC T-5, 3.42 gears w/ Auburn posi. MSD 6A, edelbrock TES headers, dynomax 3" cat and cat-back system, ACCEL coil, polyurethane bushings all around, aluminum driveshaft, Mr. Gasket open air cleaner.
1993 S-10 w/ 4.3L V6 TBI, slightly bigger cam, Mild polish job and 3 angle valve job on heads, Edlebrock TES headers, Dynomax cat back, MSD 6A, ADS chip
2000 Kawasaki KX 125
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The early 10-bolts in thirdgens are 7.5", and the later ones are 7.625". I dont know the changeover year but I think it was 1985.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
rudolphschenker
Sep 4, 2015 02:41 AM
