Funny Noise
Old Aug 29, 2008 | 02:27 PM
USchevyMC's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Funny Noise
I hear a noise that seems to be coming from the front tires, that does not sound normal. This noise only happens when the car is in motion. It makes a duh duh duh with a slight hum noise. When I go about 15mph the sound is pretty loud and when I pick up speed to about 70mph the sounds seems to fade but is still there, just not as loud. Any ideas???
Old Aug 29, 2008 | 04:46 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Funny Noise
Have the tire balance checked.
Old Aug 29, 2008 | 08:58 PM
87IROC92RS's Avatar
Car: 87 IROC
Transmission: built 700R4
Axle/Gears: 3:27 posi
Re: Funny Noise
had the same problem with mine. had the tires balanced and it still made it. ended up being a couple shims falling out of the control arm
Old Aug 30, 2008 | 01:44 AM
BLACK87ZEE's Avatar
Car: 87 Z28
Engine: 406 SBC
Axle/Gears: 4:10's,Eaton Posi
Re: Funny Noise
Could be the steel belts are letting go in the tire(tread seperation or buldge in the tires) Could also be a wheel bearing coming apart,since you mentioned a humming noise. Are your tires directional?
Old Aug 31, 2008 | 12:26 PM
USchevyMC's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Re: Funny Noise
Yea they are directional and, they are new, so I figure that they balanced them when they got put on. If its the bearings, how would I go about fixing that problem? Is it very hard to do by yourself or should I just get it done?
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Randomtask2
Sep 7, 2015 05:06 PM
