Changin drums to discs???????
Old Dec 11, 2000 | 12:08 AM
IROCracer's Avatar
Ok, I've heard that 9 bolt disc brake setups will bolt to the 10 bolt drum rears easily. Is this correct?? If not, what will it take to change from drums to discs? I trashed my 2.77 rear, and of course, it's a pain to find a new rearend. 9 bolts of the 3-series variety are hard to come by, and 3-series 10 bolts with posi and discs are hard to get ahold of around here too....plus the fact, if I do find one, the bastards want no less than $400 for them.
Thanks for any help.
Kelly
If you've gotta fix it, fix it better than stock.
Old Dec 11, 2000 | 01:52 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
From what I know, no you cannot take the discs off a disc brake rear and stick them on a drum brake rear. You need to swap the whole rear end.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Dec 11, 2000 | 03:27 PM
IROCracer's Avatar
Yeah, I've heard this too. But what exactly stops one from doin this? In other words....WHY can't I put discs on a drum rear?
Old Dec 11, 2000 | 06:38 PM
merf23's Avatar
the flanges on the ends of the rear end housing are different for drums and discs. They could be cut off and welded, but its easier and probably cheaper to buy the proper rear.
Old Dec 12, 2000 | 05:19 PM
IROCracer's Avatar
Oh god....you're not talking about those little flanges that hold on the backing plate with four bolts are you? (That's what it does on my 9 bolt anyway). Those little 2"x2" bastards on either side? If that's the only difference, maybe I should just start buying the hell outta these POSI drum rears and swappin them out.....good god that's easy. I took those off when I did my 1LE brake upgrade. Somebody verify this please, I'm gettin too excited here.
Kelly
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
jrdturbo
Mar 31, 2016 02:58 PM
92projectcamaro
Dec 8, 2015 12:25 AM
KO1
16
Oct 15, 2015 05:00 PM
indygene
Sep 26, 2015 11:21 AM
