well i grenaded my first rear..... W/I
Old Dec 11, 2000 | 01:48 PM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
Well here i am, having spun 3 teeth off of my pinion gear i have lotsa choices to make now . What gears are the choice? What should i upgrade? The rear was/is a 85 7.65 3:42 posi,26 SPLINE. I don't have alot of cash though. i will put my 9 bolt 2.77 back in. for now time isn't that big of a deal being this far from race season. Who (if needed) should i get axles through? Also do you recommend using the old posi or looking for the 4th gen take-offs from slp?? HELLLLLLLPPPP. I don't know if i am cool for being in the "i just blew up my rear-end club" or S.O.L. for having a dead IROC thnx to all, you guys 'ROC
'89 SHAGGY IROC
L98 7r4, all free stuff,T.E.S.,HOOKER CAT BACK,KYB,ACCEL8.8,JET fan sw. etc.
so much to do , so little money
Old Dec 11, 2000 | 03:25 PM
IROCracer's Avatar
Hey man, I'm in the same boat. Cratered my rear, little cash, no car.
Rear ends are hard to come by around where I live unless you want drums back there (ugh). What stops a guy from putting disc brakes on a drum rear? I'm not afraid to fabricate.
I'm gonna keep an eye on this post. And I'll repost if I find anything man.
Good luck,
Kelly
If you've gotta fix it, fix it better than stock.
Old Dec 11, 2000 | 09:22 PM
OLDYELLR's Avatar
Car: '85 IROC
Welcome to the club. I broke my spider gears and posi (Eaton Locker) last fall. The gears are okay, so I'm planning to upgrade to 28 spline axles and stick in a take-off Torsen from SLP.
1985 Yellow IROC-Z 5.0 HO, T-5 3.73 Posi, 4 wheel disks
PFCM pads, GTA wheels, Koni yellows, B&M Ripper, Dynomax
Old Dec 13, 2000 | 12:08 AM
btt , all others welcome.
'89 SHAGGY IROC
Old Dec 13, 2000 | 01:22 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
IROCracer, the mounting flanges on the end of drum axles and disc axles are different. Drum axles have a rectangle-shaped flange with a hole in it (for the brake line), disc axles have a square-shaped flange. The bolt pattern's different between the two brake systems.
I suppose the drum flange could be modified...?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
dimented24x7
Sep 17, 2015 06:58 AM
BigWhiteGTP
May 20, 2005 12:31 AM
pOOn
Jan 28, 2004 11:41 AM
