Detroit tru trac...
Detroit tru trac...
Anyone used one? Liked it?
I want to use my stock 2.73 gears on it, so I will get the 3.08 and down one. But was wondering if I will have to re-shim gears and reset the mesh. I dont have the expieriance or tools to reshim gears.
I want to be able to drop out my open pumpkin and unbolt ring gear then bolt on the ring to new carrier then put in car add LS additive and some 80w-90. Nothing else. Can I do this?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Detroit tru trac...
your going to have to at least check/re-shim the carrier bearings. And the ring gear is pressed on, you can get it off without a press, but you need one to get it back on, as well as install the bearing on the new pumpkin as they usually dont come with bearings.
I dont know what your feelings are toward 4th gen rears, but you can probably pick up a 4th gen rear with the zexel posi, which is the same idea, for about the same cost as the detroit tru-trac and get better brakes as a bonus.
sometihng to look into
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I like my detroit true trac....
But yea, you'll need to check the pattern. If you can get the new posi back into the case without destroying those goofy cast iron shims (best of luck...) then it'll probably still fit fine. Probably is the key word, if not you need a shim kit.
You can't do this with the rear end in the car, well you could, but it would be a BAD DAY to say the least.
And why bother with 2.73 gears?!? Swap those to junkyard 3.42/3.73's while you're there, you got friggen overdrive anyway!
Yea, My camaro gets bad eneough gas mileage anyways and I like my 2.73s. Just need posi. I spin all the way through first at the strip. I will have to start hunting for a 4th gen rear I guess. I dont want the rear tires to stick out though.
Looks like my best bet is get the tru trac professionally installed.
Engine: 355, 408
Well if your set on the 2.73s I have an axle out of a 98 SS with 2.73s and a good zexel torsen unit if your interested
86CamaroDan
Sep 29, 2015 10:08 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
Pilotrick50
Sep 2, 2015 12:48 PM
