Dana 60?
Old Dec 14, 2000 | 11:17 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Dana 60?
All the talk lately about Dana 44's and Ford 9" rears has made me curious, has anyone here ever run a Dana 60 under a thirdgen?
1984 Camaro Z28 Astral Silver w/ 2 1/2" cowl induction hood
Engine: Decked 383 cid 4 bolt w/ oil cooler, 9.6:1 compression, ARP fasteners, 600 cfm Performer carburetor, Torker II intake, Performer RPM Heads, XE268H cam, Magnum roller tip rockers, MSD6AL ignition, Blaster2 coil, recurved HEI distributor
Exhaust: Terminator headers, Custom 3" TIG welded stainless exhaust, Twister muffler
Transmission: 4L60 w/ Corvette servo, .500 boost valve, TransGo 7-CS clutch springs, 700 PKH pump rings, 700-2 reprogramming kit, Borg-Warner High-Energy frictions & bands, 2400 RPM lockup torque converter
Drivetrain: 2.73:1 limited-slip Dana 44 w/ disc brakes
Tires: Front P225/50VR15 Rear P265/50VR15 Eagles
Old Dec 14, 2000 | 12:18 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I think Hot Rod has a writeup on the Dana 60 this month. (If it wasn't the Dana 60, it was some other Dana... but it's not a 44.) They put it under that Montego they've been working on; which uses leaf springs- so you'd have to change the perches. That's all I know
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Dec 14, 2000 | 01:46 PM
KAOSRacing's Avatar
One of the GM Performance test mule 4th gen Camaros (I think it has a HUGE big block in it right now) is running a Dana 60. I remember seeing it on a TV show where they were grudge racing that Camaro and a tuner Ford Mustang. The Camaro broke the Dana on the drag strip.
John Guynn
Old Dec 14, 2000 | 02:58 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Oooh... I'd LOVE to break a Dana 60
[This message has been edited by Apeiron (edited December 14, 2000).]
Old Dec 14, 2000 | 11:32 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You need a lot of abuse to break a 9.75" Dana 60. It's a real big and heavy diff. I don't even see many of them at the race track any more. A few of the old dodge cars still use them.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Dec 15, 2000 | 12:36 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I've seen them on plenty of Chevelles and other older muscle cars, just wondering if anyone ever felt the need to have that kind of strength on a thirdgen. Or more impressively if anyone ever actually NEEDED that kind of strength on a thirdgen.
Old Dec 15, 2000 | 05:02 PM
Jeff Hauge's Avatar
DTS is going to make bolt-in assembalies for the third gen camaro. $1900 ouch!! But they aren't ready yet.
sailtexas186548
Jan 19, 2016 12:21 PM
Americanmouse
Sep 7, 2015 12:10 PM
Chevy3shitty
Sep 1, 2015 09:22 AM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
MENINBLK
Aug 5, 2015 11:58 PM
