Whats this built TH350 worth?
Old Dec 6, 2000 | 03:31 PM
HighCountry's Avatar
A guy I know is selling a TH350 that was in his 750 horse big block K5 Blazer. He says make him an offer. He also said it cost 2200 bucks to build that tranny. Is it worth my time to even think about a TH350 for my 3rd gen, and what should I offer him?
Thanks all for your advice
Old Dec 6, 2000 | 04:31 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I'd imagine you could rebuild one yourself, and beef it up for much less...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Dec 17, 2000 | 09:27 PM
812MANY's Avatar
I paid $250 for a rebuild kit(paper & rubber and Raybestos clutches), and paid my buddy $100 to rebuild it (he builds race trannys).
He blueprinted it and added a few extra clutches and steels.
If you want to beef it up even more you can get a stronger sprag for about $200.
As is it's supposed to be good for 600-650HP. With the sprag- ~800HP.
I also had the torque converter (non-LU) rebuilt and "tweaked" to a 2600RPM stall for $40.
The previous owner had installed a B&M shift kit, that stayed the same.
It shifts BAD @SS! it will chirp the tires at 1/4 throttle on the 1-2 and haze them on the 2-3 at WOT (behind a Goodwrench350).
You can get an aftermarket TH350 built the same way for about $1,000 and a converter for about $200.
Old Dec 17, 2000 | 09:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A K5 Blazer would be a 4x4. Let him keep the tranny. It would cost you even more because the 4x4 tranny bolts right to the transfer case. You need to strip it down and put the proper length tail shaft on it to work in a car.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
romcjr
Sep 17, 2015 05:18 PM
89newfun
Sep 16, 2015 09:28 AM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
383cam
Sep 9, 2015 06:01 AM
