I think my 700 just died
Old Dec 17, 2000 | 11:01 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
Was driving the IROC down the hwy. and went to pass a car...floored the gas and it downshifted then the rpms shot up like it was in neutral. I was about to turn anyway so I took off from the light and thought everything was okay. Went through 1st no problem, shifted to second just fine, but wouldn't shift into 3rd. Then it started slowing down. I could hold 30mph w/ the tach sitting on 2500.
Pulled into a gas station to check the fluid...off the dipstick so I put in 3(!) quarts to fill it back up. I don't know where the hell 3 quarts could have gone, but anyway... SAME THING. Made no difference whatsoever. Basically I lost 3rd and 4th gear. I'm thinking it ran low SOMEHOW on fluid and cooked the bands/clutches/maybe the sprag (?). What do the experts think?
thanks,
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N
Old Dec 18, 2000 | 06:05 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
You probably burnt up the 3-4 clutches, then the tranny got hot and puked out vent tube. It happens, time for a rebuild. Sorry.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass,
SSM SFC, Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Gunner242
Dec 25, 2015 04:49 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Giocio
Oct 1, 2015 12:20 PM
Luigytico09
Oct 1, 2015 08:46 AM
