T56 swappers, question on the pedals
Old Dec 23, 2000 | 10:10 PM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
I installed my pedals today, from a 96 Z28. Whata complete pain it was. I spent a good hour trying to line up the bolts for the master cylinder and the clutch cylinder. Finally I just ripped the pedals out and noticed that one bolt hole(the one I couldnt get lined up right) was much smaller than the others. I drilled that baby out and the pedals popped right on. Is this common? The hole was not big enough to fit on my stud. Anyways, maybe it will save some one else a headache, trial fit your pedals to the master cylinder. I havent seen this problem listed on any of the T56 swap howto's, maybe some one can add it.
Mark Lock
- 86 IROC-Z - Torn down for 383/SuperRam T56 setup
- -= IROC Online =- - The site dedicated to the IROC-Z
Old Dec 24, 2000 | 03:47 PM
IROCracer's Avatar
Coulda saved yourself a lot of hassle by buying pedals from a third gen with a T5. I spent probably 30 minutes total on my pedals.
Kelly
If you've gotta fix it, fix it better than stock.
Old Dec 24, 2000 | 08:11 PM
Birmass's Avatar
The thirdgen pedals are pretty much exactly the same as the fourth gen's except the accelerator pedal is attached. I got a set out of a 94 and just cut the accelerator off. The top (fifth) bolt was just barley misaligned too. All pedal sets are within tolerance though.
LOCK: I had the EXACT same problem too. I just drilled it out a little so it would go on easier just like you did.
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
SIX-speed
open 3.73's
2 1/4 stock catback
I love pissing those LS1's off
My Formula
Old Dec 26, 2000 | 12:22 PM
Christobal's Avatar
Same as Birmass. I don't remember clearancing any of the holes, but may have.
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
