View Poll Results: Term for limited Slip Rear
Limited Slip
53.85%
Positraction (posi)
46.15%
Open
0%
I don't know
0%
Voters: 13. You may not vote on this poll
Poll
Old Sep 8, 2008 | 07:11 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Poll
What term should be use for Limited Slip Rear?
Old Sep 9, 2008 | 07:16 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Re: Poll
A limited slip rear is called limited slip for a reason. It provides traction to one wheel and only that one wheel until it begins to slip, loose traction, and then transfers some of the power to the other wheel. When the slipping is over it resumes giving full power to only the one wheel. A posi provides power to both at all times. An open unit provides power to one wheel only at all times.
I'm right, right?
Mike
Old Sep 9, 2008 | 07:26 PM
DJP87Z28's Avatar
Re: Poll
I'm right, right?
Mike
NO, NO and again NO....
Old Sep 9, 2008 | 08:49 PM
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
Re: Poll
Posi and limited slip differential are interchangeable terms right? depending how you use the term. Meaning that that they have they have either mechanical, electrical, or vacuum clutches that allow the gears to slip in different situations? which differs from fully locked? am I in the ballpark?
Old Sep 9, 2008 | 09:06 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Poll
Yes. "Limitted Slip" is the technical name for it, "Positraction/Posi" is the marketing name for it. Same thing.
Old Sep 10, 2008 | 04:19 AM
DJP87Z28's Avatar
Re: Poll
Yes......
ROCHEAD
Jul 22, 2002 07:30 PM
Ions91Z28
Jan 13, 2002 07:22 PM
89transam
Jan 1, 2002 12:57 PM
stevenmh
Sep 26, 2001 06:00 PM
stevenmh
Sep 26, 2001 12:40 AM
