HELP:T-56 installed now battery is draining!
Old Dec 26, 2000 | 06:36 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
I just installed my transsmision and now my battery is draining very fast. I had a B&M megashifter and the wires that went to the sensors so it has to be in neutral and park to start i have to touch one of them to a postivtive source with the ignition turned to on position to start the car. I think some wires are grounding and makeing the battery drain. does anyone have anyother suggestions???
I need help asap.
aka:15 year old camaro freak
owner of a 91 z28 5.7l camaro
Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Trans Go Shift Kit, 2k Stall, B&M Rachet Shifter, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
Old Dec 26, 2000 | 07:50 PM
Christobal's Avatar
As we all know, fast is a relative term. How 'fast' is the battery, say losing the ability to crank the engine etc.?
Old Dec 27, 2000 | 02:56 AM
Car: 1991 Z28
Well I got a jump from a friend. it charged to almost 13 and I got about 2 miles before the engine sputtered to a stop.
Old Dec 27, 2000 | 02:03 PM
Christobal's Avatar
I see. Assuming your battery isn't defective, it sounds like an extremely fast drain. It would seem to me, wherever that energy is going, it would show some symptoms, like quite a bit of heat capable of causing smoke or fire.
Are the lights in your console, or any area that may have been disturbed while you were swapping, in order? 1 small lightbulb left on and hidden somwhere can drain a good battery in a day or two.
It seems to me you may have some other problem contributing to the battery drain.
Old Dec 27, 2000 | 02:07 PM
Bort62's Avatar
Sounds like a Massive short To me
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Livin' the Stereotype
Old Dec 28, 2000 | 11:22 AM
Car: 1991 Z28
It was The Alternator but thanks Chris my shifter light in the center console was shorting.
91 Z28 5.7l Camaro
T-56, Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
Old Dec 28, 2000 | 01:15 PM
Christobal's Avatar
Glad you found the problems.
Frozer!!!
Jan 19, 2024 04:55 PM
justin57
Aug 20, 2015 07:05 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
djmarch
Aug 9, 2015 05:27 PM
