is my tranny shot?
Old Sep 9, 2008 | 09:00 PM
1986 iroc z28's Avatar
Car: 89 formula
Transmission: t5
Axle/Gears: open junk
is my tranny shot?
i just got a 1987 z28, that somebody has converted to an edlbrock carb and intake setup, instead of the tpi it is suppost to have. anyway it has a 350, and 700r4, my problem is when i put the car in reverse it acts like its in neutrol, so i give it a little gas, and it "grabbs" a little, but just enough to move, so basicly its slipping. And when your cruising along at 45mph, it slipps between 3rd, and 4th, like it cant make up its mind. But when you take off it doesnt slip at all, and it shifts fine too, so is something out of adjustment, or is the tranny toast? Thanks for any input.
Old Sep 9, 2008 | 09:05 PM
performabuilt's Avatar
Re: is my tranny shot?
Unfortunately sounds like its time for a rebuild or replacement, The reverse issue is certainly mechanical
Old Sep 9, 2008 | 09:11 PM
Car: 89 formula
Transmission: t5
ok, thats kinda what i was thinking, now the question i have is, what recomendations do you guys have for a good reliable tranny.
Old Sep 10, 2008 | 11:51 PM
87IROC92RS's Avatar
Car: 87 IROC
Transmission: built 700R4
Axle/Gears: 3:27 posi
the stock 700R4 is a highly reliable and durable transmission for the car ( OD is nice ) or a th 350 ( if you dont want OD or a 4th gear for that matter ) or you could always convert to a manual
Old Sep 22, 2008 | 07:13 PM
gmpptech's Avatar
If they put an edlbrock carb on it, did they get the correct tv cable bracket an dadust it right? Sounds like your not building enough pressure.
Mirror Image
Oct 29, 2017 09:51 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
JSDaddy189
Sep 26, 2015 03:50 PM
IROCZ1989
Sep 4, 2015 11:54 AM
