swapping WC T-5 from auto
Old Dec 26, 2000 | 08:12 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
I am trading my beyond dead 200c in favor of the WC T-5 from a '91 RS. I want to ramain smog legal, and so I want to keep my computer. For the speed sensor to work, I need to change the electronic speed sendor unit in the tranny. My question is, is this possible? And if so, where do I buy the mechanical unit, and what do I do?
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
Old Dec 27, 2000 | 06:12 PM
stingerssx's Avatar
Or, can I keep the electric drive unit, and bypass the vehicle speed sensor or something?
Old Dec 27, 2000 | 06:13 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You didnt find someone to trade with?
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Dec 27, 2000 | 08:11 PM
cfabe's Avatar
If i understand the situation correctly, you're swapping in a t-5 with an electronic vss in place of the 200c that had a mechanical speedo drive.
The 82 has a VSS as well. If you have cruise control i believe the VSS in integrated into the cruise module on the drivers side of the engine compartment (someone correct me if i am wrong here.) If the signal that the new VSS will put out is the same as the old one, you should be able to just splice into the old VSS wires and connect your new VSS. You may need to get a VSS buffer (located near the ECM.)
If you do use this setup, you'll also have to change the speedometer head to an electronic one, and you will need the buffer box to drive the electronic speedometer.
Another option (possibly easier) would be to find a t-5 tail housing from a mechanical speedo t-5 and swap that in. You would need to use the appropriate speedo gear to calibrate the speedometer.
I'm in the middle of a transmission swap, a electronic t-5 in place of a mechanical TH350. I have a donor car with all the parts needed so I'm swapping all of the electronic VSS componenets in to the 82.
82 T/A 305/TH350; soon to be 350/T-5
Old Dec 28, 2000 | 02:05 AM
stingerssx's Avatar
Kevin, I don't want to trade it, just make it work. Thanks anyway.
cfabe, that's what I'm wondering, if the two vss's have the same out put. If they do, then I'll be happy, and I'll get a later model, 140 mph speedo. But if I can't splice in the speedo, I really don't need to know how fast I'm going anyway. Do I need to change the whole tailshaft, or could I just swap the mentioned piece? If I do have to swap it all, Are they both the same?
Old Dec 28, 2000 | 02:40 PM
Kevin91Z's Avatar
In your first post you were looking for a mechanical speedo hookup. I meant, find someone with a mechanical who needs an electronic, and trade them. It'd be much easier than trying to put an electronic speedo in an 82, I think. But I've never done it.
Old Dec 28, 2000 | 05:51 PM
stingerssx's Avatar
Yeah, it would be easier, but I want to keep the WC-T5. I don't want a regular T-5. This tranny is really nice.
Old Dec 28, 2000 | 06:28 PM
Kevin91Z's Avatar
No no no... You arent swapping transmissions. You are just swapping the speedo sensor. You keep your world class T5, but you get a cable speedo unit for an 88 or 89 Camaro. Its a direct swap. Tom Keliher was looking for an electronic one, last I heard.
Old Dec 29, 2000 | 05:33 PM
stingerssx's Avatar
Thank you for setting me straight, Kevin. I didn't know that you could do that. I saw another post about it. Are they all the same size? Could you give Tom my e-mail address, or direction to me, if I can't find him first? Thank you for all of your help.
Old Dec 30, 2000 | 02:03 AM
Kevin91Z's Avatar
Tom's email is tkeliher@socal.rr.com
Old Dec 30, 2000 | 04:13 PM
stingerssx's Avatar
Thanks Kevin.
Old Dec 30, 2000 | 04:36 PM
Tom Keliher's Avatar
Stinger: yeah, I have a mechanical speedo output on my WC T-5 and need an electronic VSS output from a WC T-5. Wanna trade?
FORMULA 350 TK
Southern California 3rd Generation F-Body OrganizationŠ
Old Dec 30, 2000 | 07:27 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
i have a electric unit on my wc t5 and need a mechcanical one I am also willing to trade??? Kevin
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
LittleFranks
Sep 17, 2015 12:22 PM
gta90
Sep 15, 2015 04:00 PM
midge54
Sep 2, 2015 06:27 PM
