89 RS rear axle change to limited slip disc brake
Hello,
I've an '89 RS with 5.0 and want to change out existing standard rear axle (2.73:1) with same gear ratioed limited slip rear axle with disc brakes. Does anyone know what models of camaro came equpped this way and if the axle will bolt into my RS?
Also, will there need to be any brake master cylinder changes due to change in config in the rear end?
Chris
Chris
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 89 RS rear axle change to limited slip disc brake
JamesC
Thanks for the info James. GM came out with equiment codes on their axles, would it be the best to search for a rear end with the equipment code that matches the options I'm looking for? I realize the disc brakes would be obvious but the limited slip would be less noticeabe - unless all rear ends with disc brakes were equipped with limited slip.
My first choice is to find a used one, but I'm also interested in aftermarket equipment. Do you know of any links to vendors for aftermarket rear ends?
Thanks again,
Thanks again,
Thanks again,
Thanks again,
The numbers are stamped on the ring and pinion:
41 : 15 = 2.73
41 : 14 = 2.93
40 : 13 = 3.08
42 : 13 = 3.23
41 : 12 = 3.42
41 : 11 = 3.73
You might check with Spohn, a board sponsor, for after market.
JamesC
Thanks again for the info, one last question, what year model range of rear axles will bolt into an 89 RS? I'm thinking 1985 -90 but I'm not sure, the Haynes manual I have really doesn't have a lot to say about it.
Thanks,
Chris
Thanks,
Chris
JamesC
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
When searching for a rear end, especially a 2:73 gear ratio one, just call Junkyards and ask, when i was searching for my rear i always got this answer. "well i have plenty of 3.08 and 2.73 disc brake posi rears". I would encourage you to try and get some taller gears, maybe some 3.23" or 3.42"s.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
