replacement dipsticks for th350
Old Sep 11, 2008 | 11:13 AM
HottestZ28's Avatar
why are they all extremely long unless you want to spend $80 on a braided one
I bought a TCI fill/dipstick tube for a th350 and it runs like 5 inches over the valve cover almost as high as the air cleaner
any options on better fitting
Old Sep 11, 2008 | 11:30 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: replacement dipsticks for th350
The "universal" replacement dipsticks tend to be a length more appropriate for trucks. You might try picking a random car application and seeing if the OEM dipstick is still available at the dealer.
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I have had the same problem. I bought a TH350 out of a truck, which the tube is too long for the camaro. I bought a chrome tube that was the right lenght, but would bend to easy and not fit well.
I placed both tubes side by side and marked the longer one. I then cut the longer one and used the dip stick from the shorter chrome one. Everything worked out fine except for a leak. The factory truck one and the chrome one have the o-ring. I and searching for one that has a boot type seal. These work better and are not prone to leaks.
If we could fined one that has the boot and the correct length, then the part number should be made a sticky.
maroe624
Apr 16, 2017 08:29 AM
matthew911
Aug 12, 2015 09:38 AM
mizz0313
Aug 12, 2015 06:45 AM
Fronzizzle
Aug 9, 2015 01:15 PM
Leggman1
Aug 6, 2015 04:15 AM
