im having a problem here
Old Sep 11, 2008 | 09:46 PM
eeeeeefirebird's Avatar
i bought a used 700r4 from somebody on this site. they said that it was from a 1989 firebird 5.0. the id no. on the casing proved it was from an 89. however i went to line it up with my engine today(89 iroc 5.0) and there is a stud at the very top of the point on the engine, and no accomodation for this stud on the transmission. all the other studs lined up with the holes though... is this trans for a v6 or is this just a camaro to firebird issue?
Old Sep 11, 2008 | 10:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: im having a problem here
If it was a V6 transmission it wouldn't even be close to fitting.
Old Sep 12, 2008 | 12:32 AM
hm so i guess i can pull out the top stud and line it up then. thanks for the help
Old Sep 14, 2008 | 05:08 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The 7th bellhousing bolt location on the block wasn't used in the 70s or 80s. If you have the other 6, you're good to go.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
